| Water pump? seal; I need help. | |
| Tweet Topic Started: Oct 31 2012, 10:41 PM (597 Views) | |
| christsmirror | Oct 31 2012, 10:41 PM Post #1 |
OK So I am resurrecting this g10, I have replaced the waterpump, the oil pump, the front and rear crank seals, the cam timing gear (thank you j63812f, moneys on its way), I have new timing belt, and acc belt, I'm going with full synthetic oil after the first 500 mi, And I have found a seal in the back of the water pump housing that I can not find a replacement for. does anyone know where I can get a new one, or how to make one that will work. The seal is between the intake pipe, and the water pump housing. |
| Memphis metro | Oct 31 2012, 10:57 PM Post #2 |
If your speaking about the oring on the tube, take the tube to napa and let them match you up a oring for it out of a oring kit. |
| christsmirror | Nov 1 2012, 08:40 PM Post #3 |
Thanks I have tried Autozone, and Oreillys but neither have it. I will try NAPA. |
| Memphis metro | Nov 1 2012, 09:18 PM Post #4 |
They probably will not have the oring according to the vehicle but they can match one up that will work out of a oring kit that has many differant sizes. |
| Good bye | Nov 1 2012, 11:25 PM Post #5 |
A close o-ring and some silicone sealer and your done. ![]() |
| 1.0smallblock | Nov 1 2012, 11:36 PM Post #6 |
DirtBag
the o-ring that goes on the coolant tube end (C) i replaced the o-ring seal (E) with GM part #9605-9933
| Jittney | Nov 2 2012, 12:10 AM Post #7 |
Good posting, 1.0smallblock picture plus part number
3:19 AM Jul 11
