5th gear rattle
Topic Started: Nov 2 2012, 10:14 AM (444 Views)
Smidgen
Smidgen
When driving at freeway speeds the shifter rattles. If I hold it or put pressure in a certain spot the rattling stops. The shifter in neutral is not overly loose. It only happens in 5th while at cruising speeds (55-65MPH). Anyone know what can be causing this? Bushings?
Have a look at your bushings. Mine does this too. I have not spent a lot of time chasing it though.
