| Gear Box Oil Seal Leaking | |
| Tweet Topic Started: Nov 2 2012, 10:27 AM (871 Views) | |
| fas133 | Nov 2 2012, 10:27 AM Post #1 |
I have suzuki swift 1996 1.0L and it's gear oil seal is leaking.How it would be replaced do i have to open gear box for it? https://docs.google.com/document/d/17lYT1wSbAtndt1DxS1g5tf0d2WAgVvSaq2Ch7-e2rDk/edit Edited by fas133, Nov 2 2012, 10:29 AM.
| patrickbruce | Nov 2 2012, 12:42 PM Post #2 |
average teenage gearhead
stickshift or auto? is it leaking from the axle seals or elsewhere? |
| fas133 | Nov 2 2012, 02:28 PM Post #3 |
it has manual transmission and the oil is leaking where gear shift stick connects the gear box. |
| starscream5000 | Nov 2 2012, 02:47 PM Post #4 |
This should help you out *click me* |
| fas133 | Nov 3 2012, 07:03 AM Post #5 |
Thanks @starscream5000. Although my cars transmission has not that access cover but i got the idea. |
| Jittney | Nov 3 2012, 11:35 AM Post #6 |
If your transmission doesn't have the triangular access cover, can you find a number that is stamped on the transmission? |
| fas133 | Nov 8 2012, 06:05 AM Post #7 |
@Jittney I have found the triangular access cover when searching for the stamped no. it was not visible because of dirt.And the oil seal that was leaking has bent lips from one side(seems that something hit it from underneath) so i hit it with hammer after removing the rubber boot and it stops the leak for the time being. @All Thanks for your help. |
3:33 AM Jul 11
