| Stalling out when stopping; Engine dies when coming to a stop | |
| Tweet Topic Started: Nov 2 2012, 02:53 PM (821 Views) | |
| SoCal John | Nov 2 2012, 02:53 PM Post #1 |
First, let me thank all of you for the great info I picked up off this forum to rebuild my G10. Been back on the road driving my 94 metro now for 5 months, getting 38-40 mpg and loving it. Recently though, the engine begins running rough and then dies occasionally when I'm coming to a stop at an intersection. I usually throw it into nuetral just before I stop and rev it to keep it alive. Only when coming to a stop then ideals perfectly without a miss. I'm thinking fuel issue, but hoping someone out there may have a place to start looking. Any ideas? Thanks in advance. |
| posgeos | Nov 2 2012, 09:34 PM Post #2 |
Been experiencing a similar problem and have been posting for help with a couple replies. Title of thread is "fuel system diagnostic help posted by posgeos If your idle speed is really low you might crank it up a few rpm and see if it makes any difference. It might be loading up when you come to a stop. Good luck. |
| GoCanucksGo | Nov 2 2012, 10:01 PM Post #3 |
I've also been experiencing a similar problem, I had a mechanic diagnose it a fuel pressure regulator problem. Metros are supposed to be 20-23 Psi I think, while mine was running at 13-18 Psi. Maybe run a fuel pressure test and see what kind of numbers you get? |
| RumpledSuit | Nov 2 2012, 10:05 PM Post #4 |
993cc & 234cc
my 89' escort had the same problem. I fixed it by swapping out the entire throttle body with one from a junk yard car. That year Escort was CFI (central fuel injection) like the Metro is. If you can find a donor car it is a easy swap. |
| mecevans | Nov 4 2012, 09:00 AM Post #5 |
No such thing as "loading up on decel" on a EFI car. Tps must be out of adjust. |
| gamingdevil | Nov 9 2012, 02:25 AM Post #6 |
I had this same issue, but the car would either die when idling at the stop or die as soon as i pressed the gas. My issue turned out to be debris on the butterfly valve inside the throttle body. The dirt was causing the valve to not open properly so I guess the car was choking out when I pushed the gas. All I had to do was take the fuel injector out and spray some carb cleaner inside the throttle body and all over the butterfly valve. Hasn't died on me since. I got the car for 200 bucks because the owner assumed it was a fuel pump problem. |
| Old Man | Nov 9 2012, 02:30 AM Post #7 |
clean your fuel injector |
| dayle1960 | Nov 9 2012, 06:34 AM Post #8 |
A burned #2 valve will cause this symptom. How many miles do you have on the engine? At 135K most metro engines have burned valve issues. Not all metros, but quite a few develop a burned valve.
Edited by dayle1960, Nov 9 2012, 06:34 AM.
3:18 AM Jul 11
