G13BB Head and valve train compatibility; SUZUKI VITARA 1.3 1.6 SOHC 16V CYLINDER HEAD
Topic Started: Nov 2 2012, 10:48 PM (1,004 Views)
michaelgjones7
I have a 1999 Chevy Metro LSI with the G13BB engine configuration and the origional 16 valve SOHC efi head. Question: is the Suzuki Vitara 1.3 1.6 SOHC 16V cylinder head compatible with my block? Is the cylinder head displacement the same, and if not how will it affect my: compression ratio, performance, reliability, longevity and gas mileage, etc?. Is the valve train/geometry compatible, with the Vitara head/cam on my block, or does it result in a critical/interference condition? Can I just buy the OEM cam for my car and solve any such problem? I need to replace my head NOW and want to know if you would you do this?
Michael J.
I think it just bolts right on. You need to decide if it's a 1.3 or a 1.6 though, can't be both. It'll say on the block, either G13B or G16A. Doesn't really matter, they're either identical, or the 1.6 has slightly bigger valves, not 100% sure, but it won't make much difference either way.
Ooops, keep reading.
Edited by Woodie, Nov 4 2012, 05:52 AM.
3tech
The 1.6 cam is different (dist drive) and some have the injectors in the head, and some in the intake. They are not interchangeable as far as I know. The valves are the same size.
2000Firefly1.3L
as long as the intake ports have a pear shape (for injectors) the casting for the engine head is identical. good to know if you're trying to get a replacement but no metros around. as said above camshaft is no good since it's for use with distributor
