NEED HELP ON FRONT BRAKES; PICTURES INCLUDED
Topic Started: Nov 3 2012, 01:21 PM (908 Views)
paul11211
So today im doing the front and rear brakes, well I did the front driver side and everything thing went smoothly the part that slides out of the hub came out easy, well when I went to do the passenger side that part came out hard! I had to use a pulley puller to get it out, now im wondering if I need to replace this? It has ridges it the middle of the smooth part? I looked inside the hub and found the bearings all moved freely and looked good? But I do not know why it was so hard to get off? Do you guys think this is damaged or not? Or are these sometimes just hard to get off? Thanks. :shake :shake
THIS IS THE PART THAT WAS HARD TO GET OFF, YOU SEE HOW IT HAS THOSE RIDGES ON IT, I DID NOT NOTICE THEM ON THE OTHER SIDE, ARE THEY SUPPOSE TO BE THERE? tHANKS.
I LOOKED INSIDE THERE IN THE BEARINGS AND IT SEEMS TO LOOK GOOD, WHEN I PUT BACK TOGETHER SHOULD I GREASE IT UP?
bansheetaz
the ridges are fine. just machining marks from when they made the part. wipe off all the scuz and lube it all up good. put it back together. happy motoring
paul11211
That what I was thinking that it was machine marks, Thanks
paul11211
Oh, And those stubid little clips that sap on the back of the pad into that square, I threw those in the garbage, I do not know how you get those back on, it has to be impossible!!!!!!!!
paul11211
Does anybody know how much I should torque the big 30mm nuts that thread onto the axel? Thanks.
Heres a thread on that topic:
http://geometroforum.com/topic/3821953/1/
91 ragtop
If one side came off easy there might be something wrong with that side. They are pressed on and you are supposed to pull them off and reinstall with a axle puller attachment on a slide hammer according to the book. I've never had one come off easy.
Ken......
paul11211
Nobody here has had one of there sides come off easy? What should I check for? I think it is fine, I had to tug at it a little , but I got it off by hand? Does that mean I should replace the whole hub assembly? Thanks.
Geoke
Maybe you were doing something else also but why did you pull the whole hub to do brakes?
paul11211
I had to replace the rotors they were all scratched up.
paul11211
I could not push the piston all the way back on the calilper, I think I need a new one? I have a 1991 geo metro, what calipers are interchangable? I saw a 91 90 93 at the scrap yard, will that work? Thanks.
nwgeo
Yep, Those will work for a 90. This is the dumbest question........ Just kidding ^o) Yep 89 to 94 at least.
paul11211
Im just going to do what Jonny said and use break silencer instead of those stupid clips, now im wondering if I should do the wheel bearings and everything while I have it taken apart? Thanks.
DesmondGhostRider
I'd go ahead and do the bearings while you have it undone, if you ever drive in any bumpy roads or any gravel/off road then go ahead and do it.
Its only 16 or so more to do the bearings so go ahead and do it bore they start to go when you dont have time and cost you time and mpg from the dragging.
