| Hesitation; hesitation | |
| Tweet Topic Started: Nov 6 2012, 09:05 PM (413 Views) | |
| Vaultgirl | Nov 6 2012, 09:05 PM Post #1 |
The Snail (1.0 92 auto) is hesitating when the accelerator is pressed, I just got it up and running again a few weeks ago and it ran like a new car!!! I'm not kidding!Now this! Also, the engine clatters this is new. Checked plugs, rotor, and wires all basically new. Ed I found the problem. In the pics below you can see tha the shaft key has gouged out. Also, I've posted a pic of my fix. Ed http://imageshack.us/photo/my-images/641/dsc02536j.jpg/ http://imageshack.us/photo/my-images/213/dsc02544c.jpg/ http://imageshack.us/photo/my-images/194/dsc02540om.jpg/ Edited by Vaultgirl, Nov 29 2012, 09:27 PM.
| geogonfa | Nov 6 2012, 09:23 PM Post #2 |
checked timing belt? might have jumped a tooth... |
| 69 Z-28 | Nov 8 2012, 09:12 PM Post #3 |
American Muscle
Mine was doing sorta what you described. The wire from the coil to the distributor had worked itself loose. Was barely making contact. I took a screwdriver and spread apart the contacts so they would fit tighter. Instantly started running good again. |
3:18 AM Jul 11
