| Female succeeds in changing alt belt but can I do the wheel bearing; Wheel bearing on front right all all the grease falling out | |
| Tweet Topic Started: Nov 8 2012, 12:47 PM (965 Views) | |
| tamwe | Nov 8 2012, 12:47 PM Post #1 |
I did it this morning and IT WORKED!!! Thanks so much, guys. I hope I didn't bend anything using a crowbar to push the alt and tighten the belt. It sure was nice to hear the engine purr without the squeaky belt. I think I'll keep a little of this grease on my arms just to look tough. The reason I parked the car for so long is the wheel bearing roars when I turn the wheel to the right and it's gotten so bad it's almost unbearable. So while I'm under there with the new belt project I see all the grease falling out. That bearing is shot. So is it out of the question that I might change that puppy out....a similar attempt on a trailer wheel did not go well for me years ago (I didn't know about the little saw bit trick, though) |
| tamwe | Nov 8 2012, 12:48 PM Post #2 |
A garage quoted me $140 to do it (and I don't have\won't have the money until January). |
| bansheetaz | Nov 8 2012, 12:49 PM Post #3 |
you will probably need a press to do a front wheel bearing. if you dont have access to one you could just pull the spindle and take it to a shop who can press a bearing in and out for you.
Edited by bansheetaz, Nov 8 2012, 12:49 PM.
| tamwe | Nov 8 2012, 12:56 PM Post #4 |
Good idea. That may be the cheapest way to fix it and maybe they'll just charge me $20 or so. |
| tamwe | Nov 8 2012, 12:58 PM Post #5 |
I was told the bearing is about $35. Another shop tried to fix it years ago but they changed the wrong side.
| bansheetaz | Nov 8 2012, 01:26 PM Post #6 |
exactly. i would also not take it to the shop that changes the wrong side |
| bennie442 | Nov 8 2012, 09:20 PM Post #7 |
Although I don't have a 2000 year model service manual ( or car ) to speak of, from experience on a multitude of other vehicles of various manufacturers, no bearing press should be necessary, or was necessary, to replace front wheel bearings. Front wheel drive axles though are a different animal altogether. If, for any reason ,you find yourself needing to replace a front drive axle due to bearing noise, it's cheaper to buy re-manufactured axles, rather than rebuild them yourself. Rear axle bearings on a rear wheel drive car,on the other hand,a bearing press is mandatory. Front wheel drive bearing service is a do it yourself in the drive way project,and should be no problem. If in doubt, refer to the on line service manuals. Better yet, snag a factory service manual that applies to your year vintage Metro that pops up for sale on E-bay. You can usually score one of them for about $30'ish dollars. Money well spent to avoid getting ripped off from shops telling you that you need to have new bearings pressed off/ on. Spindle bearings are a do-it-yourself driveway project. Drive axles, not so much, but, hey, that's what this forum's about. |
| Jordan | Nov 9 2012, 06:05 AM Post #8 |
If a vehicle has pressed-in wheel bearings, then a press is required to replaced them. Front wheel bearings on these cars are not what I would consider a driveway job - axles, on the other hand, couldn't be easier. I changed both of mine in about 15 minutes. Not sure what you're talking about here. ![]() To the OP - if you're seeing grease everywhere, sounds like it might be a CV boot torn. Are you sure it's the bearing that's leaking grease everywhere? I had a really noisy axle on my car that just howled when I turned. |
| snowfish | Nov 9 2012, 07:28 AM Post #9 |
Agreed. If this looks familiar............... ![]() ![]() it's a corrupt CV joint.
| Johnny Mullet | Nov 9 2012, 07:47 AM Post #10 |
You should not see grease leaking from a bearing, but if it is humming or constantly grinding and changes pitch when curving, then it's bad. If the noise is a "click click click" when taking off and worse when turning, then the axle needs replaced instead. If it's just a bad axle, then you can do this in a few hours (newbie time) and about 60-70 bucks for the axle. |
3:18 AM Jul 11
