What size rims do I need
Topic Started: Nov 10 2012, 10:11 PM (512 Views)
Tubablake
What size rims do I have.
They are the original stock with 145p/80r12 tires on it.
I want to get proline alloy rims
Syleion
12 inch rims I believe, same as most geos before 96 I think it is? The bolt pattern is 4 x 4.5 or 4 x 114.3. So any rim you find with that bolt pattern will fit.
Edited by Syleion, Nov 10 2012, 10:26 PM.
Tubablake
If I want 13 inch rims can I just take them off an old Vert?
clarkdw
Yes or a newer Metro, Swift, etc. All fit but you need to use bulge nuts to use the 13" rims with the 10MM studs.
http://www.ebay.ca/itm/10mm-x-1-25-ATV-Lug-Nuts-Chrome-Black-Blue-Red-Flat-or-60-Degree-Tapered-/290810825713?pt=Motors_ATV_Parts_Accessories&hash=item43b5ad0bf1&vxp=mtr
The 60 degree taper ones will do the job.
