Question about waterpump
Topic Started: Nov 12 2012, 05:41 PM (446 Views)
Edmayr
For the guys who have done a waterpump. Does a 98 suzuki swift have 2 weep holes 1 on top 1 on the bottom? I have a coolant leak once the system builds pressure. No water from the hole on top of the wp. It does'nt look like the rear o ring either.
Thanks Ed
PA.metro,fixer,frames,ect
Frame Fixer
Get a dental mirror..look on underside of water pump....and different types and brand s...holes can be anywhere...hopefully you find leak.... and not a head gasket..... .
Check out post 134 here http://geometroforum.com/topic/4464045/9/ you will see a hole on top and a hole on the bottom. It usually leaks from the bottom and is not easy to see without a mirror as suggested. It probably is your water pump.
