| Tapping noise coming from Valve?; 1996 Geo Metro 1.0L 3 Cyl | |
| Tweet Topic Started: Nov 13 2012, 05:55 PM (699 Views) | |
| dtricks | Nov 13 2012, 05:55 PM Post #1 |
So I am hearing a tapping sound coming from the valve covers. My buddy says I need to adjust my valves, but from my research, there is no possible way to adjust them, because I have hydraulic lifters. I'm not really sure what this means. Could I have a bad lifter? What would it take to replace? I have replaced a cam and lifters in my 350 V8, so how hard could it be??? I'm thinking if I remove the valve cover, and tighten down one of the valves, I should be okay. Sorry I'm kind of all over the place, but is there a guide to removing the tapping sound? It seems like this is a pretty prominent problem. |
| patrickbruce | Nov 13 2012, 06:08 PM Post #2 |
average teenage gearhead
if its just tapping, the lifters may need rebuilt because they're sticking..... |
| starscream5000 | Nov 13 2012, 06:20 PM Post #3 |
If you can do it on a V8, then this will be a breeze. Take the timing cover off. Air filter hat valve cover cam Then you're there. How to rebuild the lifters. |
| wizard 03 | Nov 14 2012, 03:14 PM Post #4 |
It is either a broken spring, sticking lifter, or loss of oil. Take off the valve cover, and let the diagnostics begin!
3:18 AM Jul 11
