| The 99 still had much to give.; Removing everything worth having. | |
| Tweet Topic Started: Nov 18 2012, 07:37 PM (380 Views) | |
| Three Bangin | Nov 18 2012, 07:37 PM Post #1 |
Had a 3/5 at local junk yard. Metros are rare here so I had to check it out. Under carriage was beyond rotted but struck pay dirt anyway. Harvested timing cover, lifters, distributor, Throttle body injection assy, exterior trim, front seats, turn/ wiper multifunction switch, HVAC controls with cables, working dash vents, EGR valve including solenoids/transducer,crank, MAP, coolant temp, IAT sensors, pedal pads, dome light, extra relays, bulbs/sockets for cluster, full size spare wheel tire, and my faavorite, the little plastic clip that holds the hood prop rod in place when hood is closed. |
| Harleymetro | Nov 18 2012, 07:59 PM Post #2 |
Good find
| idmetro | Nov 19 2012, 07:08 AM Post #3 |
Very nice! Good to know that the poor expired beastie will help others to continue motoring. |
1:51 PM Jul 11
