Convertible Upper Radiator Support (Tie Bar); difference between non-vert?
Topic Started: Nov 27 2012, 03:53 PM (1,396 Views)
bbowens
Hi, I need to replace the upper radiator support on my vert, and it has a different p/n than for the non-vert's. Does anyone know what the difference is? I'm being told by many that they are interchangeable.
96067327 for vert's, 96067328 for non-vert 89-94
http://parts.nalleygmc.com/showAssembly.aspx?ukey_product=3172835&ukey_assembly=389904
The vert has a driver's side SRS system. The sensor is mounted on the upper radiator support. There are probably a couple of holes or some minor difference between the two.
bbowens
thanks, Glenn, I found it. Here's some pics:
Edited by bbowens, Nov 27 2012, 06:22 PM.
I found one.
http://www.whiteracingproducts.com/index.php?main_page=product_info&cPath=1471&products_id=320038
I could probably remove the one off my vert.
bbowens
Nov 27 2012, 11:53 PM
thanks, but I'll either modify a regular one, or scrap this body altogether
bbowens
Nov 28 2012, 08:32 PM
Check the link above where I said I found one. They're pretty reliable. I installed my upper radiator support with #10-32 aircraft structural screws rather than welding.
bbowens
thx, glenn--finally was able to purchase a good body
Edited by bbowens, Dec 3 2012, 03:18 PM.
