Virgil K's Chevy sprint (rant) column; On going project
Topic Started: Dec 29 2012, 08:17 PM (11,189 Views)
Vkhelldog
I'm irritated so I'm going to rant. First of all my head rebuild went find. I put in a new o ring on the distributor/timing adjustment and.... That o ring the 15/16, 1/8 whatever it leaks. #2 I'm getting oil leak from under the timing cover already... #3 the new water pump sift come with new bolts so while torquing to 8 ftlb one broke. So here's what I am thinking. Another new water pump, new bolts this time, re re re do oil pan Rtv, put new oil pump seal/gasket, sleeve cam and crank, new seals "for the 2nd time", get proper. O ring from here, if it leaks after that I'm selling it and buying a ford focus. Can't afford to put MORE money into poor geo/Chevy sprint :-( so frusterating...
Pretty well all fixed now see pages 1-.....?
Edited by Vkhelldog, Mar 17 2013, 06:50 PM.
Vkhelldog
I guess I should be glad I have more power better mileage, and I got my heater working and my windshield washer working.... But still.
Stiffchezze
Sir Metrologist
Let it ALL out. :banghead :'(
We're here to help. ^o)
After it passes and you get to feeling better, PM me your address and I'll send you a correct O-ring. :thumb
Assuming you haven't done something as unwise as selling the poor thing. :scared
Alpine
1020cc G10 GOML
sometimes the pan gets to warped imo, and will always leak like mine!
i think im going to try a cork gasket with rtv.
the o-ring, are you sure its not leaking from the gasket between the head and dist. housing?
Mythstae
Alpine
Dec 29 2012, 09:15 PM
OMG noooooooo! :'(
Those cork gaskets will ruin an oil pan! Don't do it!
They're too thick, and soft. You tighten down the bolts, and the pan sinks down into the gasket under the bolt head. Carnage!
Vkhelldog
Alpine
Yup it's the o ring. I was planning to get one from geo Glenn but waiting till payday. I think they won't leak once sleeved. I hope
Vkhelldog
Fixed the other leaks now I'm trying to fix my distributor have it mostly apart, can't figure out how to do the next bit. Grrrt
Vkhelldog
Help! How do I get this out to replace the seal/bearing?? Posted Image
1991 distributor
Ty!
id like to know how you figured out that it was leaking inside, it looks spotless to me. I have a good 1991 dist i was saving for nightmare if i needed it later on, id sell you reasonable. But i still doubt it was leaking in there, probably the main Oring was leaking and you assumed (incorrectly) that it was in the dist leaking.
Vkhelldog
It was leaking in there, I've cleaned it... There was a lot of oil in it... The dist cap had oil in it it was making her run rough... It's not leaking on the new external o ring that Glenn sent me that I covered in sticky goo, it's leaking in this seal/bearing inside here that I can't figure out how to get apart.... The parts house guy is blaming my brand new PVC valve saying there shouldn't be enough pressure to shove oil into this tint guy....
Vkhelldog
I realize its "covered" here. http://geometroforum.com/topic/5016443/1/. However there's no details or pics of removing the iner parts... It LOOKs like a ring in there rotates and comes out, pulling shaft bearing seal... But I can't get it to turn.. I've ordered the seal/bearing listed there for my car...
Vkhelldog
I might have to buy a new one after I get done trying to get it apart :-S... 175$ for a rebuilt off autozone
geo pet
" my strange addiction "
I seen a great writeup about this in "docs greasy socket garage "
Vkhelldog
Ah ha indeed I found it there Ty very much!
go here and look at the next to last posting (#6 of the 7 postings) there is a detailed "How To" disassemble the rest of the dizzy
http://www.teamswift.net/viewtopic.php?t=27516
