Rear window trim removal?
Topic Started: Jan 24 2013, 11:30 PM (629 Views)
jasonhensley
How do I remove the rear window lower trim molding on my 96 GEO METRO HATCH BACK. pics. or video any thing?
geopat
the glass on the hatch or the side of the car?
2000Firefly1.3L
should be held in with four screws
nwgeo
I need to remove the rear side window on a 96 metro. Anybody do this.
I have done this on the 89 to 94 and that is pretty straight forward but not on a 96 or newer.
Don't want to mess up the trim or break the window of course.
Wow this is an old thread. (I have searched the how to's and googled removal for geo metros on the forum and only found this old thread)
freegeo
On the 95 up hatchback, the rear side glass has to be removed with piano wire. It is glued to the body.
nwgeo
Thanks Freego! Yep, I was able to take the trim on the side window out with much persuasion and carefulness... $6 at PnP. After starting to get the trim out I could see that it was glued in. Oh man yeah piano wire effort is not a lot of fun, but I can do it if someone does not get them first or break them.
A flexible putty knife works wonders for the rear side glass
geogonfa
Found this to work well when removing a side glass... :type
Harbor Freight;
Windshield Removing Tool # 60298
Dystopiate666
Tree Banger
Putty knife or butter knife heated up works good for thick spots in the urethane or corners of the window.
