Engine Temp issues/overcooling; Won't warm up
Topic Started: Jan 25 2013, 03:09 PM (1,349 Views)
cwatkin
I have had two thermostats fail on G10 engines. One failed open and the temp would drop to almost nothing. The other failed closed and I was glad I was pulling into my place as the temp was starting to climb. The failed open one had a busted shaft while there was nothing obviously wrong with the failed closed one. I assume it got hung up.
Conor
Tinker1980
Finally got the chance to install a new 195 degree t-stat... it seems to have fixed the overcooling issue. Too bad so many seem to be defective out of the box.
