1.3L rocker arm
Topic Started: Jan 30 2013, 07:39 PM (1,777 Views)
Metro1998
Just wondering what keeps the rocker arm from eating into the head on those 4 cyl? :drool Is there like a pin on the underside of the rocker arm or something? :hmm This is a 97, i think 95 to 97 had this problem,thanks for all the help great website! :rocker
Oil.
The rocker arm floats freely on the shaft.
Metro1998
Geo Glenn
Jan 30 2013, 07:45 PM
Oil.
Why is it wearing on the head?
How much wear is there?
My G13BA has signs of metal to metal rubbing against each other. The wear is negligible.
Metro1998
Geo Glenn
Jan 30 2013, 08:06 PM
About 3 of them are doing that it runs really smooth If it was a busted piston wouldn't it be missing or running rough or something?
Engines with broken pistons run really well. I drove one from Charlotte to Philadelphia and then to Wichita before it got fixed. They're noisy at idle, but run nicely. Not recommended, OK?
The hydraulic lifters on the G13BA get noisy because someone forgot that changing the oil is a good idea.
Replacement is easy. A new set of lifters is not so expensive. Change the oil and filter when you install them.
Check Ebay.
http://www.ebay.com/itm/FORD-GEO-SUZUKI-MAZDA-86-97-1-3L-1-6L-2-2L-SOHC-8V-VALVE-LIFTERS-LASH-ADJUSTERS-/150822202859?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AGeo%7CModel%3AMetro&hash=item231db42deb&vxp=mtr
