Car dies while in idle; Idk
Topic Started: Jan 31 2013, 02:48 PM (630 Views)
Pavelivanov22
I'm driving and the car would die when it's idle and I'm on a red light. It would slowly start whacking engine and start dying I would have to tap gas peddale to make sure it don't die. Anyone know what it might be?
geoguyxfi
throw a fuse in to sot on fuse block and see if any codes pop up
Compression test.
Pavelivanov22
its a 93 i dont know where to read codes. I did compression test they came out dry test 130 60 and 30.. from right to left
Pavelivanov22
i mean left to right
If those compression numbers are in any way accurate then your car shouldnt even be running. Those are VERY poor compression numbers...very :O
patrickbruce
average teenage gearhead
wow..............
redo that compression test, let's see how they come out; did you make sure it was WOT?
Burnt valves.
