what is this code po113; 97 geo 1.0 showing iat sensor 1 ckt high
Topic Started: Jan 31 2013, 06:53 PM (913 Views)
william tanguis
Help me
Make sure the iat sensor harness plug is connected to it. Remove the negative battery cable for ten seconds and replace it, or if you have a reader, erase the code. Drive the car and see if the code returns.
william tanguis
The car will not start no spark n no pulse to the injector
william tanguis
What is the iat
william tanguis
Can this be y
The IAT plugs into the air cleaner housing near the back.
Metro1998
william tanguis
Jan 31 2013, 07:21 PM
What is the iat
It is the intake air temperature sensor it tells the computer what degrees the air is coming into the engine. ^o)
william tanguis
Ok thank ya'll
william tanguis
Ok thank ya'll
