| Compression numbers on rebuilt engine; 110 psi on rebilt engine | |
| Tweet Topic Started: Feb 2 2013, 03:17 AM (1,208 Views) | |
| Michael_B | Feb 2 2013, 03:17 AM Post #1 |
Rebuilt the engine in my '95 Geo Metro 1.0L and just did a compression check. I have about 3000 miles on the engine right now. I get about 110 psi on all cylinders dry and around 115 psi wet. This seems low to me or is this normal? I had 140 psi on all cyliders before the rebuild. I know compression should be around 190 psi. Thanks for your help. Update... I did forget to hold the pedal to the floor when testing. I will test again.Yes the engine was warm when tested. I drove 7 miles before I tested it. Rebuild... New... -bored .020" over -oversize pistons -oversize rings -rod and main bearings -valves (all) -valve guides (as needed) -water pump -oil pump The odometer said 215,xxx but the engine may not have been original to that car. The engine was never bored out before. Engine did not use oil before the rebuild and is not now either. I had a local machine shop bore and hone, deck the engine block and install the pistons on the rods, grind valve seats, valve guides as needed. I disassembled and assembled the engine myself. I obtained info on where to have the ring gaps in relation to eachother from off this site. I took no shortcuts. Not purposely anyway. Car runs just fine. There is no black or blue smoke out the tailpipe. My compression testor is brand new. From Sears and only used it three times if that. Edited by Michael_B, Feb 3 2013, 12:24 AM.
| Deleted User | Feb 2 2013, 03:32 AM Post #2 |
Did you just put in a new set of rings? Or, did you bore the cylinders and install oversize pistons and rings? How many total miles on the engine? Was it using any significant amount of oil prior to your working on it? |
| Vkhelldog | Feb 2 2013, 03:42 AM Post #3 |
Did you try another tester to be sure it isn't off? |
| Memphis metro | Feb 2 2013, 03:53 AM Post #4 |
Did you have the eccelerator pedal to the floor when you tested? What does rebuilt mean to you? Just asking. Means a lot of things to a lot of people. All new valves? Any machine work done? New rings? |
| Smidgen | Feb 2 2013, 09:27 AM Post #5 |
Smidgen
All the above Plus. Was the car warm when tested? |
| lelio | Feb 2 2013, 11:37 AM Post #6 |
Lelio
yeah does the car run well ? if it has ac does it choke it way down ? i rebuilt mine didnt bore it just honed it and i had 180 on my comp test on all cylinders , so i bet you didnt preform the test right or something is wrong . i would think you should see black smoke if u messed up those rings and plenty of it . |
| Michael_B | Feb 10 2013, 01:17 AM Post #7 |
I did forget to hold the pedal to the floor when testing. I will test again. Yes the engine was warm when tested. I drove 7 miles before I tested it. Rebuild... New... -bored .020" over -oversize pistons -oversize rings -rod and main bearings -valves (all) -valve guides (as needed) -water pump -oil pump The odometer said 215,xxx but the engine may not have been original to that car. The engine was never bored out before. Engine did not use oil before the rebuild and is not now either. I had a local machine shop bore and hone, deck the engine block and install the pistons on the rods, grind valve seats, valve guides as needed. I disassembled and assembled the engine myself. I obtained info on where to have the ring gaps in relation to eachother from off this site. I took no shortcuts. Not purposely anyway. Car runs just fine. There is no black or blue smoke out the tailpipe. My compression testor is brand new. From Sears and only used it three times if that. |
| Coche Blanco | Feb 10 2013, 12:03 PM Post #8 |
If it's 110 even on all three, run it for another 7,000 before you worry about compression. |
| Stubby79 | Feb 10 2013, 03:04 PM Post #9 |
Timing belt off by a notch? I'd assume it'd be noticable if it was, but perhaps not. |
| mikeallen2112 | Feb 10 2013, 06:59 PM Post #10 |
Yeah I'm guessing it has to do with you not holding it at WOT. Also just because your comp tester is new doesn't mean it's perfect. I had to rent 3 different ones before I got one that would work correctly lol |
I will test again.
2:28 PM Jul 11
