LOW COMPRESSION; LEAK DOWN TEST
Topic Started: Feb 4 2013, 07:06 AM (402 Views)
VOGLERB
Have low compression in 2 cylinders (adjacent) 90 ...... 60...... 170 Leak down test has air leaking from the adjacent spark plug hole.....tested cylinder at T.D.C. during test.
I figured Head Gasket.....put on new gasket....same issue...can I assume a warped head? I've not done a lot of engine overhaul but am pretty good at following directions and turning wrenches and enjoy messing with this stuff... pulled head off and planning on taking it to the machine shop to have it checked. Straight edged the block and it appears to be ok. Just had the head and valves done a year ago and have not had any overheating issues. Engine has just under 160,000 on it to date....
Thanks in advance!!
clarkdw
Any leakage from the exhaust? Could be two burnt exhaust valves.
VOGLERB
Put in the spark plug to stop the leak out that port.....didn't hear anything out the exhaust.
geo pet
" my strange addiction "
Look at the rings Next . If the head checks out
VOGLERB
maybe should have done the rings at the same time???
have you had any oil useage or puffs of smoke lately?
VOGLERB
ended up being exhaust valves.....no puffs of smoke but since i've got it this far apart i'm gonna go a little deeper....
Thanks everyone for your advice.....it is very much appreciated!!
Reista
Clutzy Shadetree
VOGLERB
Feb 4 2013, 01:25 PM
I was told to do a full rebuild if you rebuilt the head because the engine doesn't like a tight head but looser lower end. It was too late to save me but I thought you might like to know ^^
