| engine won't start code 21; engine rebuild now car won't start | |
| Tweet Topic Started: Feb 22 2013, 10:57 PM (969 Views) | |
| crankcase | Mar 10 2013, 12:50 AM Post #16 |
Is the connector at the distributor hooked to the wireing harness. Make shure you did not plug it into the transmission, which is the same type of plug. Can you try the distributor off the 94 motor? They only go on one way. |
| BrenBren | Mar 10 2013, 02:02 PM Post #17 |
you might be 180 out on your timing, With me and my dad it is a 50/50 chance everytime. We usually get worst of the odds. If everything else is check and is all good i would look toward your timing. All we do is rotate the cam 180 degrees and the car starts up. Im sure some one else will chime in with more detailed, if it is a timing problem. |
7:19 PM Jul 10
