| what would your car do if? | |
| Tweet Topic Started: Mar 5 2013, 04:54 PM (671 Views) | |
| iamgr8er | Mar 5 2013, 04:54 PM Post #1 |
What if your second o2 sensor (the one by the cat) was open to the open air? would it make the car run rich? what are the signs of a bad o2 sensor? what are the signs of a bad ect? |
| Stiffchezze | Mar 5 2013, 05:55 PM Post #2 |
Sir Metrologist
1) It would throw on the CEL 2) No 3) CEL Light 4) ect? Do you mean ECU?This is probably no help to you. In order to answer your questions a little better, give us a little more info as to what your thinking and what your Metro is doing. If you Metro is running, I'm 99.999% sure you can rule out the ECU. They VERY rarely go bad.
| iamgr8er | Mar 5 2013, 06:14 PM Post #3 |
Starts runs then dies. will run for about 3 minutes. after it die will not restart. compression good. fuel pressure good. though on new cap & roter. put on a spare throttle body and ecu. act like it is flooding. (gas puddle in the intake) ect= engine coolant tempature sensor, so i'm told. |
| patrickbruce | Mar 5 2013, 06:24 PM Post #4 |
average teenage gearhead
leaky injector? |
| Stiffchezze | Mar 5 2013, 06:42 PM Post #5 |
Sir Metrologist
ECT Senosr. Got it. You have a '98 thats good. With OBDII it is very easy to check on the senors to make sure they are ok. . $20 and your phone and your in the game! ![]() Link--->OBDII ELM327 Bluetooth Connector I would check fuel pressure again: Link--->TESTING INSTRUCTIONS AND SPECS FOR TESTING FOR A DEFECTIVE FUEL PUMP- Check for pressure leak down after you turn the car off. Could be a sign of leaking o-rings around the injector or a leaky injector itself. Could be a clogged/dirty injector. blue rhino offers a cleaning service. Contact him for details. |
| iamgr8er | Mar 5 2013, 08:12 PM Post #6 |
No codes |
| Stiffchezze | Mar 5 2013, 08:17 PM Post #7 |
Sir Metrologist
It's not just for codes, it also displays live data so you can see what the sensors see. I'm still betting on:
| Potter | Mar 5 2013, 08:39 PM Post #8 |
Col. Potter
Live data is the bomb... if only you could do this on the obd1 cars
| iamgr8er | Mar 6 2013, 10:18 AM Post #9 |
Injector was my first bet. So i put in a new one' no change. Later i put on a different throttle ody, .so the car has had three injectors in it. |
| Hanuman | Mar 7 2013, 12:47 AM Post #10 |
did you check fuel psi after the stall and no start? could be a failing pump |
| iamgr8er | Mar 7 2013, 05:03 PM Post #11 |
No i didnt. ill do that and get back to you in a day |
Do you mean ECU?
7:20 PM Jul 10
