stupid question; air filter housing
Topic Started: Mar 5 2013, 07:14 PM (447 Views)
fdizz
In the air filter housing stack up there is a round rubber gasket (about 4/5 inches in diameter) with a slit in the middle of it. Where does it belong?
nwgeo
Should fit on the top just below the wing nut that screws to the shaft coming up the center.
fdizz
nwgeo
Mar 5 2013, 07:18 PM
Right on, thanks!
sphenicie
not quite sure what you are discribing. the tongue that bolts to the valve cover? . 4/5"?
OH, ok. was thinkn of the rubber between top and bottom.
Edited by sphenicie, Mar 5 2013, 07:25 PM.
fdizz
Actually I think were talking about different gaskets.. it looks as if it should fit somewhere around the hole on the bottom of the housing the goes around the throttle body?
