| Any one know a source for zero gap rings for geo pistons?; Anyone make a zero gap ring for geo pistons? Custom? | |
| Tweet Topic Started: Mar 5 2013, 07:20 PM (1,457 Views) | |
| nwgeo | Mar 9 2013, 03:18 AM Post #16 |
Great discussion I sent an email to bwepistonrings.com to see what they could maybe do. Also, GG I don't understand the cylinder liner issue. Thanks |
| Deleted User | Mar 9 2013, 11:28 AM Post #17 |
Cylinder liners will wear. The factory limit for taper and out of round is 0.0039". Anything more than 0.0025" and I bore to the next size. There's no need to new pistons in an engine with out of round cylinder bores. I would suggest looking into oversize parts. The only way to get the bores in the cylinders back to standard size is to replace the steel cylinder insert. It can be done, but it's $100 per hole. |
| Coche Blanco | Mar 9 2013, 12:05 PM Post #18 |
Or use some a thin spread of JB weld equally over the cylinder walls, and have the shop bore it to STD size.
| crispycritter | Mar 12 2013, 12:57 AM Post #19 |
Let us know what you find out from bwe or whomever. Thanks cc Edited by crispycritter, Mar 12 2013, 12:59 AM.
7:19 PM Jul 10
