Engine Swap
Topic Started: Mar 7 2013, 07:55 AM (706 Views)
billay
I have a 1994 Geo Metro with a 1.0 3cyl engine with 5 speed manual. I was wanting to know if an engine out of a sprint 1.0 3cyl would bolt up without modification to the car engine or transaxle.
Chevy Sprint? No.
Suzuki Sprint? Yes. The long block will fit. Use the intake manifold, throttle body, and distributor from your '94.
billay
Thanks Glenn will anything fit?
Vkhelldog
Really? I thought my Chevy sprint was exactly the same as geo metro? Huh.
clarkdw
Any Suzuki, Geo, Chevy, Pontiac 3 cyl with a cast aluminum valve cover. Not stamped steel.
billay
Mar 8 2013, 05:47 AM
clarkdw
Mar 8 2013, 09:39 AM
:gp
This is the answer.
Good luck.
billay
Bought engine for 35 hoping to use for parts I knew the head was different so pistons crank an block different .Thanks everone
Good bye
The block and crank may work, the pistons and the head are different.
billay
Thanks to all.
