| timing tensioner bearing and adjustment bracket | |
| Tweet Topic Started: Mar 7 2013, 01:28 PM (641 Views) | |
| heckling7 | Mar 7 2013, 01:28 PM Post #1 |
WHen the timing belt tensioner bearing is bolted down should the adjustment bracket be able to move when the long stud bolt in the adjustment slot is loosened? When I tighten down my tensioner bearing I cannot move the adjustment bracked without loosening the bearing bolt even with the the long stud bolt loose in slot. I'm wondering if there was suppose to be a washer behind the bearing bolt and bracket or is this normal?
Edited by heckling7, Mar 7 2013, 01:39 PM.
| snowfish | Mar 7 2013, 02:23 PM Post #2 |
Normal. The timing belt tensioner Is Not spring loaded like a riding lawn mower blade engagement pulley. Loosen bolts, spring sets tension, bolts torqued down, timing belt tension stays, spring does nothing from there.
| heckling7 | Mar 7 2013, 03:38 PM Post #3 |
thanks snowfish I was a tad zealous and felt I over did it on the belt tension the other day as I heard a low hum around the timing belt , so I had thought I discovered a short cut to adjusting the belt tension through the rubber peep hole using my 10mm little wrench. I got the long stud loose through the peep hole but the darn bracket with slot wouldnt budge . So I had to take it all apart again to get to the tension bearing bolt which actually releases the adjustment slot as you mentioned. I've been thinking of making a little 12mm window on my timing belt cover that allows access to the tensioner bolt. Maybe next time I take it apart. Not a great time to modify things as I'm visiting family here in southern Minnesota. Thanks much
| piece-it pete | Mar 7 2013, 03:55 PM Post #4 |
Danger Will Robinson!![]() An overtightened timing belt will lead to misery. Pete Edited by piece-it pete, Mar 7 2013, 03:56 PM.
| snowfish | Mar 7 2013, 04:23 PM Post #5 |
Why? It doesn't need constant adjustment. You set it and forget it.
| Old Man | Mar 7 2013, 04:39 PM Post #6 |
some people remove the spring and adjust tension by hand. Then there is no way the spring will get loose and fall in the belt and screw it up |
| heckling7 | Mar 7 2013, 05:27 PM Post #7 |
Yes, I removed that spring as well. Seems like a risky idea from the engineers to have a loose spring hover an inch over the inside of a timing belt . Do timing belts stretch a tad over miles and time?
Edited by heckling7, Mar 7 2013, 05:28 PM.
7:20 PM Jul 10
