Valve cover gasket replacement
Topic Started: Mar 9 2013, 12:22 AM (1,138 Views)
The valve cover gasket on my Swift (1.3L 4cyl) is leaking all around and coating the surrounding area with poop so I'm going to go ahead and replace it. I assume it is a straight forward job (ie, remove the bolts holding down the valve cover, coil packs and then remove the cover and replace). Any particular brand that I should buy? Also, any sealent I should buy to put it on? Thanks in advance - Aaron V :cheers
Was gonna buy this but would like a second opinion
http://www.ebay.com/itm/BECK-ARNLEY-036-1877-Valve-Cover-Gasket-Set-/360497646342?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AGeo%7CModel%3AMetro&hash=item53ef558b06&vxp=mtr
Edited by aaronvincent, Mar 9 2013, 12:32 AM.
NAPA sells very nice gaskets and seals. Get the ones that are made in Japan. Altrom imports is the product line.
I use Fuel Lube on the mating flange of my valve cover gaskets and seal washers.
It's available at aircraftspruce.com
The 5 ounce tube will last you a lifetime.
http://www.aircraftspruce.com/catalog/cspages/ezturnlube.php?clickkey=9406
Thank you Glenn, I'll head down to NAPA to get the gasket and I'll order some of that tomorrow :thumb
