mystery oil problem
Topic Started: Mar 11 2013, 08:46 AM (1,490 Views)
The audio clip definitely sounds like a broken piston skirt.
Remove the oil pan to investigate.
And, pictures of the carnage, please?
sledgehammer
Maybe but would a broken piston skirt cause the engine to literally puke oil out the blowby.
sledgehammer
Mar 14 2013, 02:17 PM
No. Inattention to clearances and limits during engine overhaul would, though.
1.0smallblock
DirtBag
heres the sound clip
Motor is in need of a teardown.
Geo Glenn
Mar 14 2013, 12:31 PM
Glen, NO IT DOESN"T SOUND LIKE A BROKEN PISTON SKIRT!!
It sounds like a sewing machine. :D
Where was the microphone placed when recording the sound? Over the valve cover, in front of the engine, beside the TB, underneath the oil pan?? That ticking noise sounded very loud. Was it that loud in person?
Mar 14 2013, 06:20 PM
Right. A sewing machine.
:ermm: One of the least entertaining productions from "Dirtbag Productions". :shake
Many thanks to 1.0smallblock for getting the sound clip posted. ^o)
sledgehammer
I only spent a half hour on it today. 15 min standing there staring it down. And 15 draining fluids and checking compression. Left to right, 20(yes20),230,230. Dry tested. Oil pan is coming off tomorrow.
Vkhelldog
Holy *}{%^}}%#**. 20? :-( maybe the pistons broke in half or something.... :-S. is it the one that had the broken bolts above it before that's at 20? Sorry sucks but happens at least you can hopefully fix it fairly cheaply.
sledgehammer
I found the problem..........................
metromizer
and.... :popcorn
Vkhelldog
The problem was.......... Pictures pictures!
Edited by Vkhelldog, Mar 16 2013, 06:25 AM.
sledgehammer
Broken piston. And no rod bearing. Rod was that sound in clip. Piston probably broke from rod slamming on the crank causing piston to break.
