belt change affect ignition timing?
Topic Started: Mar 12 2013, 09:39 AM (479 Views)
heckling7
After changing my timing belt the other day do I need to be concerned about the ignition timing with the distributor changing a bit? If so, does it typically advance or retard some with a new snug belt?
clarkdw
If the belt is on correctly it will not affect ign timing enough to worry about. If you want to check it with a light go for it. If it has moved a lot you are out a tooth on the cam timing.
heckling7
