heater lower rpm
Topic Started: Mar 17 2013, 01:05 PM (624 Views)
brohamjeff
Was noticing that my thermostat was taking a long time to get to full operating temperature. I turned on the heater to see if there was any heat blowing through, which there was, and also noticed the rpms dropped when I turned on the heater full blast. Is that normal?
Stiffchezze
Sir Metrologist
No, that is not normal.
Your heater should not affect RPM's at all. If it does, it means your blower motor is drawing ALOT of amps. Too many in-fact and putting a load on your alternator.
I would start with checking you blower motor. Pull it out and check to make sure it turns freely. ^o)
brohamjeff
Okay. sounds good. Where is the blower motor located? And what is the best way to take it apart?
Stiffchezze
Sir Metrologist
Under the dash on the passenger side. Held in place by 3 or 4 (can't remember) 10mm nuts. One adjuster cable. I think you have to go in through the back of the glove compartment on your '93 for two of them.
It is not that hard. Once you pull one, you can pull another in less than 5 min. :thumb
RONNIEREDLINE
METRO MAD MAN
thanks stiffchezze
ive got my dash out and didnt think of checking it, im goin out right now to check mine.
mine doesnt pull the idle down, but a little lube goes a long way in prevetive maint
brohamjeff
Thank you so much for your help. I'll check this and see what I find
JellyBeanDriver
It's normal.
The blower does pull a lot of amps on high and will pull more of a load from your engine from the alternator.
Stiffchezze
Sir Metrologist
JellyBeanDriver
Mar 17 2013, 07:35 PM
It's normal.
:P
Ok, Ok it is normal for the blower to pull a good bit of amps at high speed. :whistle
BUT, it should not be majorly noticeable. Guess I should have asked how much it changed the RPM's :smackface
Still, I would check the fan to make sure it turns easily if it is changing the RPM's enough to notice. ^o)
Bill CNC
Stiffchezze
Mar 17 2013, 08:43 PM
JellyBeanDriver
It's normal.
:P
Yes, It is normal for the RPM's to jump when the fan is turned on. EVERY vehicle I have ever had, and that is a LONG list, ... has done this. Not as noticeable as when the radiator fan comes on, but it does jump.
Heater fan pulls so much that it's on the list of things which trigger the Idle Up circuit. If your idle drops, then your IAC valve isn't working right. If it were working right you'd perceive a slight change in idle but the IAC would compensate.
