| Number 2 cyclinder low compression?; How to fix? | |
| Tweet Topic Started: Mar 19 2013, 08:20 PM (328 Views) | |
| paul11211 | Mar 19 2013, 08:20 PM Post #1 |
I did a compression check and got 160,130,160. Which 160 is just above the minimum, well the other cyclinder is a little low, so I put 8oz of Marvel mystery oil in the oil, and 8 ounces of sea foam in the gas tank, hoping maybe this will loosen up the rings and bring up compression for number 2 cylinder? It is probally a long shot but yeah it was worth a try, the engine is on the edge for a rebuild, but hey I figure I can still get another 30,000 miles out of it, It is not throwing any codes, and still runs rear smooth. What do you guys think? Thanks. |
| Deleted User | Mar 19 2013, 10:50 PM Post #2 |
Seaform and MMO are part of the "Litany of Denial". 30,000 miles? Maybe. Some factor of 3 for sure. 3 days, 3 weeks, 3 months . . . etc.Plan your engine replacement early. Kinda like pre-arranging your funeral, only different. |
| Coche Blanco | Mar 19 2013, 10:52 PM Post #3 |
I think you can get another 5,000 to 10,000. 30k is definitely pushing it. |
7:18 PM Jul 10
