| Horn Wiring; A QUESTION OF ACCESSIBILITY | |
| Tweet Topic Started: Mar 22 2013, 05:01 PM (861 Views) | |
| scubaman | Mar 22 2013, 05:01 PM Post #1 |
scubaman
Horn stopped working: 1. There is 12V at the horn 2. The ground wire (blue) from the steering wheel to the fuse box is good 3. The ground from the horn (blue) is good all the way to where it enters the cabin is good. 4. between entrance to cabin and under dash, hard to access Conclusion. Wiring is damaged between Fuse box and cabin exterior. Loom is somewhere under dash. Who has experience in getting to the loom wiring? Or am i just better off splicing in a new piece of wiring. My thought is, if the ground wire (blue) is broken somewhere under the dash, why did it happen when the wire should be wrapped and cozy. Did rats eat the wire? and if so did they eat anything else? is there other damage to the loom I cannot see.? Do I have to take apart the dash? Scale of difficulty? How much time? Is there a nice tutorial? early 90's Metro/Swift Edited by scubaman, Mar 22 2013, 06:29 PM.
| Deleted User | Mar 22 2013, 05:32 PM Post #2 |
Oh, boy. Wiring. I estimate wiring jobs at one hour per wire. Then add multiplication factors. A wire going through the firewall, that's in a taped bundle is going to take 4 hours for the first wire, and another hour for each wire going the same way. Unless you're really wanting to keep the appearance OEM fresh, I would recommend roughly running a wire from A to B to see if it solves your problem. If it does, make the installation neat, wrap it, and call it a day. It shouldn't take more than an hour to fix it with a bypass wire. There may have been some rodent to the wiring, or corrosion damage in the crimped ends in the connectors. Removing the passenger front seat and tossing some padding over the bump will make your under dash experience less unpleasant. Removing the dash is ideal, but not time effective. Don't forget to disconnect the battery. Glenn |
| scubaman | Mar 22 2013, 05:54 PM Post #3 |
scubaman
glen once again thanks. hey i got the tube. Also take a look at my last post at Mag 1 Oil and did you see my article Inferior Oils. |
| Scoobs | Mar 22 2013, 06:23 PM Post #4 |
Check your fuse? Nvm seen you have 12v at the horn. Horn may very well be bad, ive seen several, including the one on nightmare quit, did a horn upgrade to caddilac horns Much better than the road runner Meep Meep
| scubaman | Mar 22 2013, 06:28 PM Post #5 |
scubaman
horn good. first thing i checked. Blue wire not going to ground when horn at steering is pressed. I know a bit about circuits Its definitely an open in the loom under the dash
| randumuser | Nov 15 2013, 08:54 PM Post #6 |
I know this is a dead post but I ran into the same problem and here is how I fixed it... here is the link: http://youtu.be/c_yOpGa1t0I
| scubaman | May 5 2014, 04:20 PM Post #7 |
scubaman
I found the wiring cut behind the left front fender. It seems the loom was chafing against the fender and cut the wiring to the horn. BEEP BEEP on the road again. |
9:12 AM Jul 11
