| Engine run on with beeping sound..; Engine run on with beeping sound.. | |
| Tweet Topic Started: Apr 30 2013, 11:28 AM (1,486 Views) | |
| Old Man | May 1 2013, 12:11 PM Post #16 |
about metro fuel injector http://www.google.com/search?sourceid=ie7&q=geometroforum+cleaning+fuel+injector&rls=com.microsoft:en-us:IE-SearchBox&ie=UTF-8&oe=UTF-8&rlz=1I7ACEW |
| Hanuman | May 1 2013, 05:40 PM Post #17 |
like he said. and one fuel injector. |
| thresher shark | May 1 2013, 10:24 PM Post #18 |
Fresh Fish...mmmm....tasty!
Here's an off-the-wall idea: when you shut off the engine the residual heat can sometimes boil coolant if the system is not holding enough pressure. A weak radiator cap could be vibrating against the radiator neck as it releases the steam. |
| 1990XFi | May 2 2013, 02:45 AM Post #19 |
1990 XFi
Everyone seems to agree that removing those 2 screws to look at the injector is not advisable so I won't try to do it. I'll look in there with a light and see what I discover. When I first bought the car I was using acetone but I was also doing mostly highway miles then. I'll try to go back to the acetone and see what happens with city mileage......thanks again guys. |
| 1990XFi | May 23 2013, 12:52 AM Post #20 |
1990 XFi
Hey guys. Just a follow up on the beeping sound. Haven't heard it in several weeks but I think that when the weather warms up and the car runs for longer than an hour that sound will return upon shut off. Regarding the engine run on after shut off which was an issue a few weeks back, I'm happy to report that with this tank I used Chevron fuel injector and the run on seems to have stopped.
Edited by 1990XFi, May 23 2013, 12:57 AM.
7:22 PM Jul 10
