$10 valve spring tool
Topic Started: May 9 2013, 12:19 PM (1,463 Views)
chinostripe
I tried for a week to find a valve spring tool to borrow from one of the local parts stores. I finally thought about it for a minute and came up with this. A $8 C clamp from Harborfreight along with a cheapo 13/16 spark plug socket that's been rusting in my tool box. I cut 2 sides from the socket to allow for tweezers and keepers. I finally added a short piece of PVC tubing to the stationary jaw to rest against the valve face. Took about 20 minutes to install all new 3tech stainless valves.
Photos - https://plus.google.com/photos/115112864207404482087/albums/5876028984272403281
I like it!
That works. Been more than one socket cut up to install some keepers. ^o)
Norby
Saweet !
buddydog201
Anybody can fix something with parts, a good mechanic improvises. Nice work
MR Bill
What size "c" clamp did you use?
chinostripe
This is the exact tool
http://www.harborfreight.com/8-inch-industrial-c-clamps-39610.html
I was just putting the pistons back in and snapped a rod bolt. Probably need to check my torque wrench. Any clues who might have one?
My FSM says 40 ft/lb. Apparently it's 26 ft/lb. cuss words.
Edited by chinostripe, May 9 2013, 05:19 PM.
26 right. You mean a FSM has a error in it? Cant be. That is only supposed to be haynes with errors.
PTA2PTB
Good job! In addition to installing your valve keepers with it, they make a really good tool for pressing your brake caliper pistons (all the way) back into their bores, so you can fit your new brake pads over the rotors, when doing a brake job. For $8, you can't beat it.
chinostripe
Do not misread the manual like I did. Stalled my rebuild immediately.
The local Chevy dealer says you can't replace the bolt. I have a rod coming. Am I better off pressing out the pin and replacing the rod, or just replacing the bolt?
mluikart
we had the same error and snapped our rod bolt, did you have any luck with finding a replacement bolt?
chinostripe
I ended up buying a rod off ebay. I got busy and it got hot so It's still sitting like I left it a few months back. The good news is I got another Geo yesterday with a good motor in it. Since my original is a 4 dr, I'm going to swap the engine from the recent acquisition into the 4 dr. I'm going to have parts available. Body and interior, no drive train.
91 ragtop
I built my own using a c clamp vicegrip. All it takes is one squeeze and you're in business.
Ken..............
Edited by 91 ragtop, Sep 21 2013, 07:07 AM.
clarkdw
I liked the one in this video so much that i built my own version. Pics later when I bring it home from work after tweaking it.
