| After engine rebuild 120 PSI compression; Need to be broke in more? | |
| Tweet Topic Started: May 17 2013, 12:18 AM (1,748 Views) | |
| Old Man | May 17 2013, 02:04 PM Post #16 |
OK.....back to your original question. 120 compression is OK for as few miles as you have on your rebuild. The compression should keep rising til somewhere between 5000-10000 miles have been put on the overhaul.--make sure you are doing the compression test correctly and with good equipment. Go here to see a good compression test procedure: http://geometroforum.com/topic/2574993/1/ |
7:22 PM Jul 10
