| Installing pistons on rods; Metro pistons | |
| Tweet Topic Started: May 17 2013, 09:57 PM (632 Views) | |
| Memphis metro | May 17 2013, 09:57 PM Post #1 |
A lot of people attempt to press pistons on rods using a press. This usually at the best leaves a piston that does not move freely and at worst bust your pistons. The correct and best way is to use a rod heater. Your pistons are loose on the rods after installed and you do not run the risk of busting your pistons. I suggest letting a machine shop put your pistons on if your changing pistons. They can install your pistons on the rods for just a few dollars and it will be done right. Call them as ask them if they have a electric rod heater to install pistons with and how much they would charge you to do it. I myself steer clear of any method that involves pressing. I have attempted the press method and done a few successfully but nothing near as good as a job done with a rod heater. Here is a rod heater, http://www.youtube.com/watch?v=7eTU3tyniJc |
| allmountain40 | May 17 2013, 10:06 PM Post #2 |
| Deleted User | May 17 2013, 10:12 PM Post #3 |
I bought the Kent-Moore service tools for piston pin removal and installation that are listed in the Factory Service Manual. My machine shop has a permanent parking spot for them in a box on a shelf. $10 per piston. First time, every time. Never a problem. If any of the Forum members want it done right, I'll take them to the shop for $10 each and the price of return shipping. A set of 3 or 4 pistons will fit in a USPS Medium Flat Rate Box. GG |
| 3cyltom | May 17 2013, 10:22 PM Post #4 |
yeah shouda hit you up for my pistons. didnt think of it and just went with my local machine shop. they broked a new piston. waiting for them to get the right tool? didnt want to attempt it myself. i just end up breaking stuff like that. |
| Memphis metro | May 17 2013, 10:25 PM Post #5 |
You should fire your local machine shop if they cannot even install pistons on rods.
| 3cyltom | May 17 2013, 10:30 PM Post #6 |
knock on wood they have done 2 heads in the past for me. still going strong. in the future i think im gonna give geo glenn a try. support our own. |
7:22 PM Jul 10
