question about using crank?
Topic Started: May 22 2013, 03:28 PM (452 Views)
paul11211
Will a 190 G10 crankshaft work in a 1996 g10? I was wondering because the 1996 had a cranks postioning sensor? THanks.
Mythstae
The position sensor stuff is on the reluctor gear (gear with teeth on the outside. Older gear had a washer under it, no teeth). Use the correct crank gear for the car and you're good to go...
The crank gear on the older crank is a 4 bolt and the newer one is a 5 bolt.
Thought this was going to be about long distance truck driving.
