Question about rebuild?; Pictures included
Topic Started: May 24 2013, 08:44 AM (443 Views)
paul11211
Post #1
- 422
- Group:
- Valued Members
- Member
- #9,130
- Apr 12, 2012
- Location
- in the hills
I just got my block back from the machine shop and I Have a couple of hollow spacers that came with it, do these go on the engine? And if so where do they go? Or were they just put in there by mistake? I am thinking they go between the block and tranny? Thanks.
Tinker1980
May 24 2013, 08:56 AM
Post #2
- 545
- Group:
- Valued Members
- Member
- #11,905
- Jan 3, 2013
- Location
- Oklahoma
- Year/Make/Model
- 2015 Mitsubishi Mirage
Those look like the dowel pins that go in the corners of the head - so the head will fit perfectly on the block.
May 24 2013, 09:36 AM
Post #3
- 15,634
- Group:
- Tech Certified
- Member
- #1,708
- Jan 20, 2010
Put them here if you have none in the head or the block for these locations. If you do have two in the head or engine block for these locations then yes they may be for the engine to transmission connection.
paul11211
May 24 2013, 05:18 PM
Post #4
- 422
- Group:
- Valued Members
- Member
- #9,130
- Apr 12, 2012
- Location
- in the hills
I did not see any on the transmission and engine? Are there suppose to be some there too? thanks.
May 24 2013, 08:32 PM
Post #5
- 15,634
- Group:
- Tech Certified
- Member
- #1,708
- Jan 20, 2010
Yes. Even the starter has a couple. Just look for the holes the size of the dowels and drive them in.
| 1 user reading this topic (1 Guest and 0 Anonymous)
