| What kind of assembly lube to use? | |
| Tweet Topic Started: May 24 2013, 07:09 PM (735 Views) | |
| rydholm11211 | May 24 2013, 07:09 PM Post #1 |
Big sky
Im using white lithium grease for assembly lube on my rebuild this weekend, and I have used it last year on a rebuild and it worked great, what do you guys use for assembly lube, some people say no white lithium, and some say that is all they will use? Thanks. |
| allmountain40 | May 24 2013, 08:42 PM Post #2 |
Lucas assembly lube. The stuff is like honey. Best assembly lube made. Once rebuilt a metro engine using Lucas, fired it up and was trying to set timing. Now normally, metro lifters take a litlle while to pump up. But after 5 minutes of running and tinkering with the timing, mine were still rattling. I looked in the driverside window and my oil presuure light was on! I shut it down and beagn investigating the issue. I had made my own oil pump gasket but had left off the round part off to one side that seals the oil pump to the pick-up so I had run my engine for 5 minutes with no oil! I fixed the gasket, crossed my fingers and fired it up. I now have 140,000 miles on that engine and still going strong. If it can run for 5 minutes with-out seizing, I'd say its the best out there.
Edited by allmountain40, May 24 2013, 08:43 PM.
| 3tech | May 24 2013, 08:55 PM Post #3 |
Grease is not the answer. I use this
| Memphis metro | May 24 2013, 09:10 PM Post #4 |
Last couple of metro engines I built was vaseline. I have used dexron before. |
| nathan298 | May 24 2013, 09:22 PM Post #5 |
Geo Resurrector
I use synthetic gear oil...but I am by no means a mechanic, so it's probably best to use something else
| Deleted User | May 24 2013, 09:25 PM Post #6 |
![]() Yes. This. |
| Old Man | May 24 2013, 09:33 PM Post #7 |
http://geometroforum.com/topic/4112800/1/ |
| nemoskull | May 27 2013, 12:16 AM Post #8 |
used mobile 1 synthetic. i am no mechanic, but it was cheap and i was poor and it seems to work good. 1700 miles in two weeks, no problems. listen to the mechanics here. |
7:21 PM Jul 10
