| 3k Engine cutout at WOT; Engine cuts out with extreme gas pedal pressure. | |
| Tweet Topic Started: May 26 2013, 08:20 PM (516 Views) | |
| Hogleg | May 26 2013, 08:20 PM Post #1 |
Midnight Toker
When I push hard on the gas pedal the engine gets to about 3k then cuts out till it gets sown to 2k then back up to 3k like a rev limiter. May be poorly adjusted throttle cable? |
| crankcase | May 27 2013, 11:05 PM Post #2 |
Throttle position sensor? |
| Hogleg | May 28 2013, 03:51 AM Post #3 |
Midnight Toker
Replaced and adjusted. No change. Is there a such thing as beyond wot? I have a vacuum advance distributor. Edited by Hogleg, May 28 2013, 03:52 AM.
| Deleted User | May 28 2013, 04:16 AM Post #4 |
You have a manual transmission? There is a throttle switch on the throttle body rather than a throttle position sensor. It has two functions. It slightly increases the fuel flow at idle, and also at higher power settings. The engine will run just fine with the throttle switch unplugged. Perhaps your distributor is in need of repair. GMF member fainya is the man. http://geometroforum.com/profile/605915/ Send him an email from this link. He's not on here, much, so a PM may go unanswered for a while. |
| Deleted User | May 28 2013, 11:47 PM Post #5 |
I just got an email from fainya. He has a vacuum advance distributor in stock, ready to go. He's going to want your core back. No holding out.
7:21 PM Jul 10
