| question about rebuild? | |
| Tweet Topic Started: May 27 2013, 01:43 PM (510 Views) | |
| rydholm11211 | May 27 2013, 01:43 PM Post #1 |
Big sky
I just did a complete rebuild on my engine, new oil pump and everything and cleaned all the lifters, and it still has a couple ticks in the lifters? I have only ran it about 10 minutes after the rebuild. But wouldnt you guys think the lifter noise should be gone by now? or do I need to just drive it and waite? And I am wondering if there is enough oil getting to the top? I took of the oil cap and saw it splashing up there but it was not spraying out pass the oil cap? Any advice is appreciated, Thanks. |
| rydholm11211 | May 27 2013, 01:45 PM Post #2 |
Big sky
Oh and all the lifers seem to look fine after I cleaned them all out? Should I put some Marvel mystery oil in? I am not sure if I should put that in right after a Rebuild? But I would think that would be fine? what do you guys think? Thanks. |
| Deleted User | May 27 2013, 01:52 PM Post #3 |
Drive the car for a couple of miles. The lifter ticking will go away. |
| Johnny Mullet | May 27 2013, 01:52 PM Post #4 |
Let it run. It can take 15 minutes or more to quiet down. |
| rydholm11211 | May 27 2013, 01:57 PM Post #5 |
Big sky
It will not hurt my engine if it has a little tick will it? I just want to make sure the valves are opening right? Thanks. |
| rydholm11211 | May 27 2013, 02:03 PM Post #6 |
Big sky
I checked my other geo metro and took of the oil cap, and it splashes way harder our of the oil cap, then the car I just rebuilt? I wonder why that would be? And I used white lithium grease for assembly lube? I think it should be getting more oil to the top? |
| Deleted User | May 27 2013, 02:04 PM Post #7 |
If the engine sounds good otherwise, don't worry about it. Ticking after installing new or cleaned lifters is normal. It won't hurt anything. |
| rydholm11211 | May 27 2013, 02:34 PM Post #8 |
Big sky
Sounds good, other than the tick, engine sounds like a beast! after I drive it it should get better, Thanks again for the advice. |
7:21 PM Jul 10
