cylinder head alignment pins; can i reuse them?
Topic Started: May 27 2013, 03:53 PM (817 Views)
geomark
I am getting ready to install a rebuilt cylinder head on my 91. The new head does not have the two alignment pins - should I remove the ones from the old head? Any suggestions for getting the old ones out? Can I / should I get new ones?
Thanks.
The alignment pin P/N is P/N 04211-13189. $1.74 each from Suzuki.
They are reusable if you don't damage them.
Use a propane torch or heat gun to heat the area of the head around the pin. Spray on some sort of penetrating oil.
They might come out by gently using Vice-Grips. Or, you can get a long pin punch and tap them out through the head bolt hole through the top of the head.
Don't worry if you ding them up a little bit. Smooth off the rough edges, and put them back in service.
geomark
Thanks. I will try some heat.
