| 92 geo metro hard knocking (rebuild or buy new engine)?; Help | |
| Tweet Topic Started: May 27 2013, 06:44 PM (584 Views) | |
| phyregoldDe | May 27 2013, 06:44 PM Post #1 |
I just recently got this car tagged and decided to drive it over to my father in laws. When i got there I turned off the car. When I got there the car was doing some serious ( i mean serious) hard knocking, it also couldnt stay running until I pumped the gas. It also takes about 5-6 times now while pumping the gas to even get it started. I litterally just got this car tagged two weeks ago... Any suggestions? Or anything else I can provide you guys to help me out? Also, is this worth rebuilding? I really have no clue what went on... Thanks! |
| Memphis metro | May 27 2013, 07:40 PM Post #2 |
Your going to have to locate the source of the knock. Depending on the shape of your car as to whether any major repairs are worth it or not. |
| phyregoldDe | May 27 2013, 07:51 PM Post #3 |
Okay, i'm a complete newb when it comes to most stuff. I can replace an alternator and a water pump. What can I do to locate the exact location of the knock? Thanks |
| Deleted User | May 27 2013, 08:47 PM Post #4 |
The crankshaft pulley might be loose. Or, you ran it out of oil. Did you check? How many miles on the car and engine? |
| Memphis metro | May 27 2013, 09:01 PM Post #5 |
If you can post a video of it knocking, you might be more successful in locating the source. |
| Awesome-X | May 27 2013, 10:54 PM Post #6 |
Definitely check the oil first. |
| cwatkin | May 28 2013, 10:54 AM Post #7 |
Is this a knock from run on or rods? You didn't make it clear. One is a matter of minor repairs while the other is not. If rods, check the oil level and then DRAIN the oil into a clean pan with no other debris/dirt in it. Pour the oil into a container for proper disposal and look at the bottom of the pan. Do you see lots of metallic flakes? Do you see chunks of metal? Conor |
7:21 PM Jul 10
