questions on rebuilding my cylinder head
Topic Started: Jun 16 2013, 01:23 PM (923 Views)
terry8750
terry8750
ive got leaking valve guide seals on my engine and was wondering how much can the machine shop mill the head before i have to start modifying ignition timing or use higher octane fuel.i would like to have it milled as much as possible for the extra horsepower but i dont want it to affect the fuel i have to use or have to reprogram the ecm or go with megasquirt.engine is a 1.3 g13 single overhead cam with coilpacks.gonna have them go through the whole head with seals guides and valves if needed.
My suggestion is to replace the valve stem seals with the head on the car, if that's all that's wrong.
Or, do nothing if your oil consumption is acceptable.
Minimal milling is all I do. Trying to modify a nicely designed engine can get you into a situation where you wish you hadn't done what you did to try to improve economy or performance.
I have a nice set of Viton/Teflon valve stem seals for your engine. If you're interested, send me a PM.
Glenn
Sinequa
Useless Twit
I went .015 on my heads(2) and both are fine with 86 octane but I also have different cams then stock and reshaped the cambers as well. So I guess this doesn't mean much for you.
terry8750
terry8750
oil use isnt much not even half a quart.i get with u later on the valve seals.it might be a month or two before i dip into it.other than that the engine runs great.im up 42 mpg avg. thank to the 3.79 transmission gears i got now instead of the 4.11s.my best on those was about 38 mpg.
econoboxer
I am the one on the left.
Geo Glenn
Jun 16 2013, 02:08 PM
Glenn
Hey Glenn, how do you do that?
3tech
Like the G10, the seals don't wear out unless you have a problem. Since your head uses the same undersized guides the G10 uses, but in a more severe environment, you will need at least some guides replaced, probably on the exhaust side, but possibly both.
I wouldn't take more than .020" off your head. Although stock it's a low compression engine, you have no way of adjusting timing, so you can't overdo it. That, and in this application, the gains will be minimal.
Have you seen this?
http://www.teamswift.net/viewtopic.php?f=30&t=48005
econboxxxer
Oct 15 2013, 06:10 AM
Geo Glenn
Glenn
You can get an adapter that screws into the sparkplug hole and use air pressure to keep the valves in place or you can go low tech, stuff the cylinder full (at the bottom of it's stroke) with rope/cord then spin it by hand to compress the rope and hold the valves in place while you dismantle/work on them. It is important not to move the crank while you are doing the work. If the valves don't seal or you spin the crank while the keepers are off the valve you could drop the valve into the cylinder and then it's time to pull the head...
terry8750
terry8750
i gotta do the head gasket too cause its starting to weep on the oil pasages.so the head will be off.but im noticing that my transmission is always cover in oil no matter how much i clean it.it might be leaking too .also the cam posistion sensor is leaking around the head.i tryed rtving it but no luck
Edited by terry8750, Oct 26 2013, 07:52 PM.
terry8750
terry8750
3tech doesn't make any adjustable cams gears for the engine ?
was wonder if u guys do performance cam grinds for this engine ?
There's a seal that you can get for the camshaft position sensor housing from Suzuki. A new one of those and little Ultra-Gray RTV on the flange, and you'll cure that oil leak.
I had a recent discussion about the possibility of replacing valve stem seals without removing the head on a G13BB with j63821f. It's not going to happen. Off with the head, and take it to a machine shop for repair. They'll let you know if you need any parts replaced. Mill as required. -0.020" off the head is an arbitrary decision that may affect your driveability, performance, and ability to pass emissions testing. -0.005" is a more typical repair to the head gasket mating surface.
3tech
terry8750
Oct 26 2013, 07:59 PM
Yes we do. Did you check out the link I posted? There's one discussed in there.
Regarding the sprocket, you don't need an adjustable one, the stock one is fine.
terry8750
terry8750
yea i read it.its an informative post.im might just have the shop shave a minimial amount off get a 45mm throttle body and header off a 1.6 swift and one for 3 tech performance cams and call it a day cause its just my daily driver gas saving work car after all.my real hot rod is in the garage.92 240sx lq4 tremec t-56 fully stripped interior and roll cage in the makings.
