burnt valve??
Topic Started: Jun 30 2013, 11:20 PM (852 Views)
wingthing2
how does a car act or what are the signs if it has a burnt valve? still trying to get to the bottom why this metro has a loss of power
good compression----doesn't use oil, cleaned out the EGR valve, new fuel filter etc etc etc........came to a stop today shifted out of 1st into 2nd stepped on the gas and the car acted like it was gonna die/lost power almost stalled, something isn't right :(
Edited by wingthing2, Jun 30 2013, 11:22 PM.
Potter
Col. Potter
burnt valve would have bad compression.....
dose the car smoke at all?
have you recently replaced the o2 sensor?
is your check engine light on?
how long has this problem been going on?
is their any odd noises from the engine like a ping, knock, clatter?
how dose your antifreeze look? level, color, and clarity.
is the car rich? (black smoke out the tail pipe)
is it too lean? (spark plugs white as snow)
dose it feel like a constant bog down or jolting bog like a cyl is only catching fire every other lick?
wingthing2
Potter
Jun 30 2013, 11:36 PM
no smoke
have not changed sensor
no check engine light
been going on since I got the car couple months ago
no engine noise
anti freeze good
no black smoke
just replaced plugs, but
the tips are whiteish color
when excelerating feels like its not getting full power
Edited by wingthing2, Jul 1 2013, 12:00 AM.
Smidgen
Smidgen
My guess is o2 sensor. Common to be bad even without CEL. For $18 give it a try. here is a link: http://www.primechoiceautoparts.com/p-9024-oxygen-sensor-mmy-geo-metro-1996.aspx
wingthing2
CEL?? what makes you think its the O2 sensor? also the check engine light isn't coming on
Edited by wingthing2, Jul 1 2013, 12:42 AM.
Cat clogged?
Do you know the check engine light works? Does it come on when you first turn the switch on? Check the timing with a timing light.
Potter
Col. Potter
:gp yea i was going to follow up with this.... pin the connector under your hood their should be a diagram under the hood and check your timing
it should be 5 deg advanced from the factory. and if you feel confidant bump it up to 8 deg it helps i prommise.
cat could be clogged as well
imo if you dont have emmisions or inspections hack that bad boy off and replace it with a peice of pipe
Edited by Potter, Jul 1 2013, 10:05 AM.
Smidgen
Smidgen
My car had the same problem. Stepped on the gas, no power. A few weeks later the check engine light(CEL) came on with pre-cat o2.
wingthing2
crazy thing is runs great and excelerates on the flat and suffers going up a long grade, could be the checkengine light doesn't work, how do ya check that?
Geo Glenn
What's in your engine?
wingthing2
Jul 1 2013, 03:31 PM
When you turn on the key, before you start the engine, all the lights should come on. Oil, alternator, check engine light, etc. That's how you check.
3 cylinder Geo Metros suck for power going up hills. I'm pretty sure what you're experiencing is normal.
Geo Glenn
Jul 1 2013, 03:37 PM
wingthing2
careful GG. I told him that a couple of days ago and he told me that I wasn't making sense......He's gonna think you are a dumbass too :D
