Spring dampner for timing belt tensioner?
Topic Started: Oct 17 2013, 07:05 PM (578 Views)
evintho
The FSM calls for one and in the drawing it looks kinda like a V shaped wire. When I tore my motor apart, there was no such animal! Please explain what it looks like, where it goes, what is it's function and where do I get one!
If anyone has a pic I'm sure I could locate one at Pick-N-Pull.
When I installed the timing belt I just pulled up on the tensioner bracket to adjust the belt tension then tightened down the stud. I'm sure that's not right! Any help is greatly appreciated!
Dont need it. You did right. Drive on James.
As Big Rhino said, you're probably cool.
As long as it's not flailing about trying to jump off, or making a sick whining noise, you're close enough.
ptcapboy
don't have a spring or damper on mine and it is just fine-
evintho
Good enough for me! I'm off to go bolt on the timing cover. Thanks!
Forget it too. ^o) I run all my metros without it.
