Rumble rumble
Topic Started: Oct 18 2013, 01:21 AM (646 Views)
2000 Suzuki Swift G13BB Auto
When I come to a stop and put my foot on the brake the engine rumbles and pulses for a few seconds like its hunting for an idle and then smooths out. Vacuum lines maybe? :hmm
brake booster line and/or valve?
geogonfa
Yes...check for vacuum leaks, not necessarily the booster, but the one way check valve could be bad...
Okay, so I bought the little check valve and have run into a problem. My 4 cylinder g13bb does not appear to even have one, that or it is hidden quite well. I traced all the vacuum lines and do not see it anywhere. Found it on my 3 cylinder metro in 5 seconds but do not see it on my 4 cyl. Anyone know where it is on the G13BB?
JADEDSL2
Resident WraithSlayer
Yeah man, it's built into the hose that goes from the intake manifold to the brake booster. Don't believe me, take the hose, try to blow through it. Now flip it over, and try the other end. One way will not allow air to pass. That's your internally mounted brake booster check valve...in the hose about halfway through, you'll see a very faint bulge, that's it. If you try to squish it with your fingers, you will find it is very hard.
Edited by JADEDSL2, Oct 18 2013, 06:32 PM.
Oh g%$ dammit, of all the places they could put something. Inside a freaking tube, mehhhhhh :die
Well at least I know where it is and how to reconfigure it to work. Thanks a bunch JADEDSL2, would have never thought that bump was the valve :thumb
