| Stumped...1993 Metro starts, runs, dies | |
| Tweet Topic Started: Oct 18 2013, 09:15 AM (1,739 Views) | |
| nickb803 | Oct 19 2013, 11:09 AM Post #16 |
NickB803
Look under your drivers side dash at the wiring harness there. I had the same issue before. Turned out that the addition of the aftermarket alarm had loosened a wire causing me the same issue you have.. |
| mrchance | Oct 19 2013, 11:15 AM Post #17 |
Blucifer's owner - Brad
not enough to dent it... just taps. mag light works too haha
| CharlestonMetro | Oct 19 2013, 09:45 PM Post #18 |
Well, I have my answer of why the car wouldn't start. It was out of gas. Here's what happened: the fuel gauge quit working a long time ago and I have been filling the tank by mileage. I get about 45mpg, so I would refill it at 400. It died at 383. Since it would start up and run (and drive somewhat) I figured there was no way it was out of gas. I was wrong. On a lark, I decided to pour a few gallons of gasoline in and it started right up. I have driven it probably 50 miles without a problem. Lesson learned! As far as the intermittent not starting. I inspected the clutch safety switch...and it was unplugged. Somebody (previous owner of the car) had jumpered the plug so it was "always on." I ordered a new switch and will put it in when it comes in this week. Was that the problem? We shall see. But at least I have a running car now. As for why the gas mileage went downhill last week, all I can think is I was stuck in a lot of stop and go traffic, which may have gotten me only 38mpg. There's the update. Thanks everyone for their help. |
| MR Bill | Oct 20 2013, 07:57 AM Post #19 |
Lesson learned: time to fix fuel gage and sending unit. |
| CharlestonMetro | Oct 20 2013, 10:19 AM Post #20 |
You got that right, Mr. Bill. As always, I appreciate this online community. I've gotten more useful information (and parts...thanks to GeoGlenn) from here than I could ever get locally here in Charleston, SC. Thanks! |
| mrchance | Oct 20 2013, 02:38 PM Post #21 |
fuel, spark, compression... gotta have all 3. Refill every 300 miles. It's cheaper when fuel prices go up anyway |
| 2000Firefly1.3L | Oct 20 2013, 04:11 PM Post #22 |
you can remove the fuel pump, and measure resistance of the float lever. |
2:18 PM Jul 11
