| front catalytic converter | |
| Tweet Topic Started: Oct 18 2013, 10:56 AM (653 Views) | |
| Sinequa | Oct 18 2013, 10:56 AM Post #1 |
Useless Twit
Anybody know where I can source a new insert? I've tried looking on line and all I've found is for a 1.3. I took my manifold apart and the insert was almost completely blocked. Tried smoging it with just the rear but the NOx is to high. |
| David95237 | Oct 18 2013, 11:36 AM Post #2 |
I actually took an old cat apart and stole the core out of it , reshaped it and used in the metro manifold. Passed smog and saved it for next time. |
| David95237 | Oct 18 2013, 01:06 PM Post #3 |
High Nox is caused by a plugged egr valve or egr malfunction. and too much timing advance.
Edited by David95237, Oct 18 2013, 01:07 PM.
| Sinequa | Oct 18 2013, 02:39 PM Post #4 |
Useless Twit
If the engine was anywhere near stock yes I agree, in this case however only having a large high flow 2nd cat is not cutting it and need to install the small first one. |
| evintho | Oct 18 2013, 06:32 PM Post #5 |
Are you talking about the pre-cat that's bolted to the exhaust manifold? If so, there's absolutely nothing inside of mine. It's just a big round hollow tube! Am I missing something.........literally?! |
| David95237 | Oct 18 2013, 06:38 PM Post #6 |
Have you passed ca smog without that cat. Yes their is a honey comb in that cavity. |
| Sinequa | Oct 18 2013, 07:19 PM Post #7 |
Useless Twit
Evin yes there is suppost to be a catalyst in the hole, a stock engine will pass with just one. Modified not so much. |
| evintho | Oct 18 2013, 09:09 PM Post #8 |
Well, mine is completely hollow. I wonder WTH happened to the honeycomb?! Is it removeable? Maybe a PO took it out. I remember talking to my smog guy before I took the car off the road. A new one, installed is $300......ouch! Another $300 for the second cat too. Thank you California tree-hugging enviro-nazi's! I think I'll just leave it as it is. The motor is brand new so hopefully it'll pass smog......this time! Edited by evintho, Oct 18 2013, 09:10 PM.
| BadEgg | Oct 19 2013, 11:09 AM Post #9 |
MPG is fun
If you don't pass smog without it I have an extra cali exhaust manifold in great shape. |
| evintho | Oct 19 2013, 05:54 PM Post #10 |
I'll know in a few weeks. I'll keep you in mind. |
2:18 PM Jul 11
